Hi Dave,
Perhaps you could provide the ability to over-write the settings for a
particular object. Let's take parcels for an example. I create new parcels
and their settings are all defaulted to the current style, say with a label
bounded by a rectangle. Now, one or two of these parcels, I don't want the
label bounded by a circle but I want everything else to be the same so I go
in and modify the settings for that (those) particular object(s).
Everything else is inherited from the original style and if that style is
modified, the object would be modified as well except for the settings that
where overwritten. This way, I wouldn't have to go create a completely new
style just for one object.
I don't know if this goes completely against where Civil3D is going but it's
just a thought.
Brian
"Dave Simeone" wrote in message
news:4047942e$1_2@newsprd01...
> Is the request to have an option to turn on/off the display of labels per
> object?
> There is currently the ability to turn off label styles by type (ie, turn
> off ALL labels in the drawing, turn off all parcel labels in the drawing,
> turn off all Line labels in the drawing). However, this option doesn't
give
> you the ability to turn off the labels for a couple of the parcels. Also,
> you have the ability to remove the labels from an alignment or profile,
but
> we don't have a similar ability to remove the labels from a parcel. You
can
> delete the parcel bearing/distance labels (but not turn off). Parcel area
> labels are either all on/of by using the "Edit Label Style Defaults..."
> setting for Parcel-Area styles.
> As Jame says, you can also make a style that has Visibility "OFF".
however,
> it's a bit tough to turn the label back on because you need to
select/right
> click the parcel label to graphically select (ie, change properties) of
the
> parcel. If you know the parcel number you can change the style from the
> Prospector data view.
> We'll need to think a bit about this one...
> Thanks
> DAS
> "James Wedding" wrote in message
> news:4045e0b3$1_2@newsprd01...
> > You don't remove the labels, you would simply change the style of the
> > parcel's Label Set. It's odd, but I do believe it's there (or I could be
> > wrong, I'm not sitting in front of it right now.)
> > James Wedding, P.E.
> > IT Manager
> > Jones & Boyd, Inc.
> > Dallas, TX
> > XP/1 on P4-1.6/512
> > LDT2004+C3D
