just a couple of thoughts on
Edit User Defined Property Fields:
1) User Defined Properties Field Editor
keeps centering itself within C3D graphics
area which is probably not always desired
behavior, say a user want to have a look
at the parcels which fields are being
edited.
2) While browsing through selected parcels
(Next/Previous buttons) it'd be more gracious
if Next button is grayed out when last
parcels is reached (and Previous button
is grayed out when first parcel is reached)
rather than terminating the dialog box and
prompting for a new selection. Terminating
the dialog box should occur only for
OK/Cancel buttons.
thanks
Strah @ Langan
"Chris Putnam" wrote in message
news:8726C8648FB0F596A8C1F62BDCE4F23E@in.WebX.maYIadrTaRb...
> The way you get to this is through the parcels menu:
> Parcels/Labels/Manage User Defined Property Fields...
> Define a new property field name as well as a default value (if you
have
> one, otherwise leave the default blank).
> To assign specific values to a given parcel, go to:
> Parcels/Labels/Edit User Defined Property Fields...
> Draw a crossing polyline through the parcels you want to edit, and the
> new property field should be listed in the dialog that pops up.
> Currently, the only supported property field type is text.
> Chris Putnam
> Software Engineer
> Autodesk Civil 3D Team
