Does anybody know of a way to generate a Coursing Table from a parcel? Attached is an example I am trying to achieve.
(I understand the attached information doesn't really add up)
Solved by bnesja. Go to Solution.
I don't think I've seen a report out of the box that will do what you want. Although you might be able to use the Coordiante Geometry Editor to copy and paste it to Excel and then add the points to the Excel worksheet.
Have you checked out this: http://www.civil3dpowertools.com/Products/VisualReportDesigner/VisualReportDesigner.aspx
If you are a pro with XML and XLS sheets you'd probably be able to export out the XML of the parcels and the use the style sheets to create the reports. Or .NET reports may also be an option.
Thought I would update this with my workaround. Not a one-click-fix but it saves a lot of time from typing and prevents typos.
