AutoCAD Civil 3D General Discussion
*Tyler Townes
Message 1 of 4 (95 Views)
Parcel Commands
95 Views, 3 Replies
04-07-2004 11:29 AM
1) Do the slide bearing and swing bearing commands work? I am having a hard time getting them to work. The slide bearing command seems to dead end. 2) Is there supposed to be create ROW command for SP1? 3) Is there a change the default "parcel style" and "parcel label styles" when creating parcels. It has been defaulting to Standard. (the dialogue box that appears every time a parcel is created). Thanks, Tyler Townes, P.E.
Active Contributor
DannyCounts
Message 2 of 4 (95 Views)
Re: Parcel Commands
04-13-2004 09:49 AM in reply to: *Tyler Townes
In regards to the CreateROW command. You have to delete the civil.mns, civil.mnc,civil.mnl under your windows profile, i.e. C:\Documents and Settings.... then restart Civil 3D and you will see this command under Parcels
*Tyler Townes
Message 3 of 4 (95 Views)
Re: Parcel Commands
04-13-2004 10:49 AM in reply to: *Tyler Townes
correction... 3) Is there a way to change the default "parcel style" and "parcel label styles" when creating parcels. It has been defaulting to Standard. (the dialogue box that appears every time a parcel is created). "Tyler Townes" wrote in message news:4074489a_2@newsprd01... > 1) Do the slide bearing and swing bearing commands work? I am having a hard > time getting them to work. The slide bearing command seems to dead end. > 2) Is there supposed to be create ROW command for SP1? > 3) Is there a change the default "parcel style" and "parcel label styles" > when creating parcels. It has been defaulting to Standard. (the dialogue > box that appears every time a parcel is created). > > Thanks, > > Tyler Townes, P.E. > >
*Glen Albert
Message 4 of 4 (95 Views)
Re: Parcel Commands
04-15-2004 06:41 AM in reply to: *Tyler Townes
Tyler, In the prospector settings tree, right click on the Parcels node then select "Edit Feature Settings". Expand the "Default Styles" category to see the settings for the parcel styles. If you want it to always default to the same style, set it here. If you prefer the style to default to the last used setting, expand the "General" category (above Default Styles) and set "Save command changes to settings" to Yes. Changing this to Yes here will only affect Parcel command settings. If you want all command settings to have this behavior you can edit it for the entire drawing by going to the drawing name root node in prospector settings, right clicking, selecting Drawing Settings then editing the General category in the Ambient Settings tab. You can also edit settings for specific commands. For parcel commands expand the Parcels/Commands node in prospector settings for a list of commands. Glen "Tyler Townes" wrote in message news:407c283a$1_1@newsprd01... > correction... > > 3) Is there a way to change the default "parcel style" and "parcel label > styles" > when creating parcels. It has been defaulting to Standard. (the dialogue > box that appears every time a parcel is created). > > "Tyler Townes" wrote in message > news:4074489a_2@newsprd01... > > 1) Do the slide bearing and swing bearing commands work? I am having a > hard > > time getting them to work. The slide bearing command seems to dead end. > > 2) Is there supposed to be create ROW command for SP1? > > 3) Is there a change the default "parcel style" and "parcel label styles" > > when creating parcels. It has been defaulting to Standard. (the dialogue > > box that appears every time a parcel is created). > > > > Thanks, > > > > Tyler Townes, P.E. > > > > > >
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
