if you are using 2007, here is a solution:
http://www.civil3d.com/2006/06/plat-problem-resolved.html
you can't split layers inside the area label style, but you can make a note
that references the parcel. James explains it pretty well.
Dana Breig Probert
http://civil3drocks.blogspot.com/
CADapult Ltd
Empowering Design With Innovative Solutions
www.cadapult.net
wrote in message news:5260124@discussion.autodesk.com...
My parcel labels look like this:
LOT 1
43,560 SF
1.00 AC
All 3 components end up on the same layer. That is fine for my record plan,
but on all the other sheets I only want to see the lot number. Is there any
way to put the lot number and the area on separate layers?
