Valued Contributor
shinysingh
Message 1 of 11 (189 Views)
Paperspace Print Issue
189 Views, 10 Replies
11-26-2012 11:30 AM
Hello There,
just a quick question.. is there anyway i can print my dwg. with white polylines.. even though my paperspace is in black color??
i have a google map as xref image and i drew bunch of white polylines showing the street... but when i convert the dwg to PDF or print it, those white polylines change to black lines.... How do i fix that?? and i am using Autocad 2012 Version.
An immediate assistance would be appreciated.
Shiny
tcorey
Message 2 of 11 (186 Views)
Re: Paperspace Print Issue
11-26-2012 11:33 AM in reply to: shinysingh
Set the color of the polylines not to AutoCAD color 7, but to RGB 255,255,255.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Valued Contributor
shinysingh
Message 3 of 11 (184 Views)
11-26-2012 11:39 AM in reply to: tcorey
i just changed the layer to 255.. but for some reason, it's still showing the black color when i print preview???
tcorey
Message 4 of 11 (179 Views)
11-26-2012 11:45 AM in reply to: shinysingh
Is color for objects set to Bylayer? Did you set the layer to AutoCAD Color 255 or True Color 255,255,255?
Tim Corey, Owner
Redding, CA
AllenJessup
Message 5 of 11 (176 Views)
11-26-2012 11:52 AM in reply to: shinysingh
If by White you mean nothing printed on a white background. You can set a color in a CTB to 0% shading and set the lines or layer to that color. That will yield white lines or text on an aerial.
Allen
Valued Contributor
shinysingh
Message 6 of 11 (173 Views)
11-26-2012 11:56 AM in reply to: tcorey
what do you mean by 'ByLayer'????
and i went to layers.. selected the appropriate layer and changed its true color to RGB 255,255,255...
but, i am still getting those black lines when i do print previe...
Valued Contributor
shinysingh
Message 7 of 11 (172 Views)
11-26-2012 11:59 AM in reply to: AllenJessup
No, allen
by white, i mean to say i have one layer with white color and i have changed its true color to RGB 255,255,255.
But, when i select the plotter as DWG to PDF.. and preview my dwg.. those white lines change to Black color lines...
i dunno how to fix that????
tcorey
Message 8 of 11 (166 Views)
11-26-2012 12:30 PM in reply to: shinysingh
Pick the objects, go to Properties and look at the color. What does it say? If it says Bylayer, these objects take on the color of the layer. If set to anything else, the layer color makes no difference. If the objects are set to White, you would not notice that their color does not change when you change the layer to 255,255,255.
Tim Corey, Owner
Redding, CA
troma
Message 9 of 11 (162 Views)
11-26-2012 12:39 PM in reply to: tcorey
On top of what Tim said, you should also check that you don't have viewport layer overrides, which could set the layer to display a different colour in the viewport than it does in model space, or different in paperspace than the modelspace colour.  Check if it is highlighted in blue in the layer dialogue, or type VPLAYEROVERRIDESMODE.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Active Contributor
rand
Message 10 of 11 (142 Views)
11-26-2012 02:30 PM in reply to: AllenJessup
I agree with Allen.  I think that's what you're looking for.
Go to your plot style table,  pick a color (I use 100), change the screening to 0, save the changes to your table, then change the color of the lines you drew over the aerial to new color (100, or whatever you picked).  It should plot white.
Good luck,
Rand
