Hello all,
I am trying to create an alignment table for a road, and since I can't seem to create an alignment report like I used to in LDD, I am copying the information out of the panorama and into excel.
The problem is I need two more significant figures in the 'Direction Column'. Does anyone know how to get the panorama to output dd.mm.ss instead of dd.mm? I know how to find the information manually if need be, but it would be nice to have the info in the panorama. I have attached an image showing the column in the panorama.
Thanks for any help,
Rand Waltz
Civil 3D 2012
Solved by BrianHailey. Go to Solution.
Solved by mathewkol. Go to Solution.
Ahh. This was the first place I checked, but I was checking the 'Angle', not 'Direction' precision.
Thanks to both of you for your help.
Rand Waltz
why don't you try panorama maker? I have used it for 2 years, it's a easy to use and professional panorama software which fits the new learners best. It not only can teach you how to stitch photos to panoramic photos but also can make 360 panorama and 3d panorama with this photo stitching software, believe me, you will be surprised after you use it.
I think ghostcat is a spambot Jeff, most likely triggered by the keyword 'panorama'.
Get outta here ya crazy ghostcat!
