AutoCAD Civil 3D General Discussion
Active Contributor
6 Kudos
Post 1 of 2
Panels Don't show up in Ribbon
389 Views, 1 Replies
06-08-2011 12:22 PM
I have a custom Ribon Tab I use when grading.  I have the Edit Geometry and Edit Elevation Panels copied from the Modify Tab.
Every Session I have to Right Click to "show" the panels.   It doesn't matter that I have saved the workspace.
This happened in 2011 and now in 2012 as well (32 and 64 bit)
Any Thoughts?
Conan Witzel
Distinguished Mentor
126 Kudos
Post 2 of 2
Re: Panels Don't show up in Ribbon
06-08-2011 08:05 PM in reply to: cwitzel
Go into the cui and select your workspace and choose customize workspace.
Go down and untick the tab you are having problems with.
Click done.
Click the Save all current customization files button. It's the little disk icon up the top in the middle.
Click ok and exit the cui.
Go back into the cui and customize the workspace and add the tab back in.
Click done, save and then ok. it should be sorted. You may have to change your workspace.
If this fixed your issue, click on "Accept as Solution"
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
Post to the Community
New Post
