Civil 3D Forum
Panels Don't show up in Ribbon
1 REPLY 1
cwitzel
786 Views, 1 Reply
I have a custom Ribon Tab I use when grading.  I have the Edit Geometry and Edit Elevation Panels copied from the Modify Tab.
Every Session I have to Right Click to "show" the panels.   It doesn't matter that I have saved the workspace.
This happened in 2011 and now in 2012 as well (32 and 64 bit)
Any Thoughts?
Conan Witzel
Conan Witzel
Civil 3d 2021 SP1.1
Smoking BOXX Apex 2 Workstation
1 REPLY 1
andrewpuller3811
in reply to: cwitzel
Go into the cui and select your workspace and choose customize workspace.
Go down and untick the tab you are having problems with.
Click done.
Click the Save all current customization files button. It's the little disk icon up the top in the middle.
Click ok and exit the cui.
Go back into the cui and customize the workspace and add the tab back in.
Click done, save and then ok. it should be sorted. You may have to change your workspace.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Rail Community
