What is the tool palette? What is the command they are trying to execute? Do
they have other versions of Autocad and/or Verticals installed?
I have had this error, but only when running a custom lisp routine that
accesses ObjectDBX. The problem is linked to referencing the incorrect
ObjectDBX version.
wrote in message news:5559421@discussion.autodesk.com...
I give up. Only one of the users is having this problem. It is every
drawing. He right-clicks on his tool pallette and he gets the following
error message:
"The A program name changed from A.exe to acad.exe. Some commands and add-on
customizations may not load correctly. Continue anyway?"
Whatever you choose, you are going to shut down. No closes the program and
yes crashes the program.
I have repaired. The error continues.
He is running Civil3D 2007/SP3 on WinXp/SP2.
Any help would be appreciated.
Josh
