What is th eproper workflow to get SSM Custom Properties to be recognized when I use the P&P tools to create the sheets? I see no way to link the dst file with the Custom Properties to the sheets that the P&P tools create.
I did setup a test sheet set with all of the custom props in fields and save it as a template.
John Mayo
Solved by Jeff_M. Go to Solution.
When you use the Sheet Set wizard you can select an existing DST, this is where the link gets created. Your attributes/text with fields need to be setup in the block 'blind' (you won't have the custom properties to choose from). In this example, my SheetSet has a custom property of "Set Total Number". So when I create the field for the totl number of sheets I must type that into the property box exactly like it is defined in the SS. Now when a sheet is created it will use the new DST's property to fill that field. I hope that makes sense. I have custom properties for the Address, City/State, Total # of Sheets, Acreage.
I can get the custom props if I start SSM and use a dst template. The Plan Production tools don't let me choose the dst & I don't get the custom props if I create sheets with the PP tools...
John Mayo
In the attachment I show a new sheet created with the PP tools and the template that I created from the SSM with a dst.
No custom props. i'm thinking they get saved to the dst not the dwt....
John Mayo
Create an empty SS selecting existing and choose the one you created all your custom fields>> PP yada yada >>add to existing Sheet set.
Like Jeff said if you dont create the customs exactly there will be a prob. I combat that by adding my PP template temporary to an existing SS with the customs and get them in the pop down.
Also, to be sure all your ssm field sould be defined in the "default" of the attribute def, not the "value"
Your Name
OK. So I choose the add to sheet set option and I get the custom fields. All is good in that areana but now I am looking for the majical save as button for the sheet set....So now the workflow breaks down again since I do not want to save sheets from a bunch of projects to the template dst file.
I would hope there is a better way then having to open windows exploder and copy the dst to the project location or removing sheets and then subsets? If there is I can't find it.
....Thinkiing about how easy it is to cut sheets in revit.....
John Mayo
Your Name
OK so you make the dst part of the project and have one dst per project. True? Do you have subsets in the SSM for different plan sets?
John Mayo
Your Name
