Distinguished Mentor
Pointdump
Message 1 of 5 (308 Views)
Overrides and Child Overrides
308 Views, 4 Replies
09-06-2013 12:14 PM
What is the difference between an Override and a Child Override?
Why do some sections have Override Check Boxes but no Child Override Arrows, and vice versa?
What happens when you click a Green Check Mark in the box?
What happens when you click a Red "X" on the arrow?
Dave
Dave
Mohave Valley, Arizona
HP DV7 Laptop
Intel Core i7-3820QM 3rd Generation Quad Core 2.7 GHZ CPU
16 GB DDR3 RAM ( 2 DIMM ) / 180 GB SSD
Nvidia GeForce 650M Graphics w/2 GB Memory
Windows 7 Professional 64 bit / AutoCAD Civil 3D 2014
So the green check means that decimal is an override to the value set at the dwg level.
The x in the child override means that you want all point styles to use the point style benchmark.
If you "accept" this then  the override will stick for the green check and the check will remain to indicate that it overrides a setting further out (parent) and the arrow (and red x) will dissappear as it will force all styles further in (children) to use benchmark.
this is a way to modify child settings of the parent setting globally because sometimes there are a lot of children involved. LOL
So
DRAWING Level (THE BIG DADDY-PARENT)
    POINT  (CHILD OF DWG and PARENT OF LABEL STYLES)
        LABEL STYLES (CHILD OF POINT and PARENT OF INDIVIDUALLY DEFINED LABEL STYLES)
           DESCRIPTION ONLY (JUST A CHILD)
john.mckenzie
Message 2 of 5 (288 Views)
Re: Overrides and Child Overrides
09-06-2013 01:01 PM in reply to: Pointdump
So
john.mckenzie
Message 3 of 5 (285 Views)
09-06-2013 01:05 PM in reply to: john.mckenzie
Or a picture paints a thousand words.
john.mckenzie
Message 4 of 5 (272 Views)
09-06-2013 01:17 PM in reply to: john.mckenzie
To further muddy the water.
If you click on the lock icon at any parent or child spot
(dwg/point/labelstyle)
You will not be able to modify that setting for any child instances (inwardly) from the place where you used the lock.
Pointdump
Message 5 of 5 (268 Views)
09-06-2013 01:35 PM in reply to: john.mckenzie
John,
OK, so there can be both Overrides and Child Overrides for any property in the Feature Settings Table. That gets me a little closer. I like your "Big Daddy Parent" hierarchical explanation. Thanks for your help.
The lock makes sense now, too.
Dave
Dave
HP DV7 Laptop
