Civil 3D Forum
override tex background text in label style
1 REPLY 1
rfg018
436 Views, 1 Reply
I like using the edit label text in the lable styles to add additional text and information.
I can turn on / off the backroung mask for all the style but not each.
Is there a way to turn on / off the backround mask of each layout text.
I'm using civil 3d 2012 and testing 2013.
1 REPLY 1
BrianHailey
in reply to: rfg018
The text override only overrides the value of the text. The property you are looking for is a property of the text component in the label and that is not an option to override with the text. You would need to create a new label style (right click on the label style you are using and choose new and it will create a Child Style) and change the settings for it and then apply that style to your label.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Rail Community
