Active Contributor
0 Kudos
Post 1 of 7
OVERLAYWIDENWITHSUPER1 zero cross slope glitch
261 Views, 6 Replies
11-02-2012 02:58 PM
with the default cross slope 2% in place and no profile targets, section views with subject sub assembly come up at 0%
there's some polyline width targets but no verticals...
any thoughts?
thx!
The superelevation parameters won't calculate and the software won't allow you to add anything until you have a design speed set for the alignment.  Open the Alignment Properties dialog, switch to the Design Criteria tab and use the button to add one.
I tried some experimenting with a single tangent alignment like yours and ran into the same problem - without any curves you cannot enter any superelevation values.  I ended up adding a very small three point curve to the end of the alignment then used masking to hide it.  Once that was done I could add the superelevation.
418 Kudos
Post 2 of 7
Re: OVERLAYWIDENWITHSUPER1 zero cross slope glitch
11-03-2012 10:53 PM in reply to: torpedo99
Check the superelevation parameters for the alignment.
Active Contributor
0 Kudos
Post 3 of 7
11-04-2012 09:01 AM in reply to: sboon
the alignment has no super parameters, therefore it seems the defaults in the subassemblies should dictate
other thoughts?
thx,
418 Kudos
Post 4 of 7
11-04-2012 09:38 AM in reply to: torpedo99
I just checked the help and the parameters for the sub.  I don't see a default slope parameter, and the help indicates that the lane slope always comes from the superelevation.  Perhaps we're talking about different subassemblies or different versions?
Active Contributor
0 Kudos
Post 5 of 7
11-04-2012 10:09 AM in reply to: sboon
I'm using 2012
In help under "layout mode operation" it sure seems to imply -2%, also in your graphic it shows a -2% slope value...
But I'm guessing you're on the right track.  However I've got a long tangent road and the super wizard simply returns "no curves on alignment" and the tabular editor won't let me add anything.  So I can't simply add 2% normal crown for the length of the roadway, hoping the assembly would kick in.
Any last thoughts?
again much obliged,
418 Kudos
Post 6 of 7
11-04-2012 05:40 PM in reply to: torpedo99
Active Contributor
0 Kudos
Post 7 of 7
11-05-2012 06:58 AM in reply to: sboon
you da man!
Thank you!
