Civil 3D Forum
OverlayWidenWithSuper
5 REPLIES 5
Joe-Bouza
370 Views, 5 Replies
I trying theOWWS for the first time and something are not going so smoothly. I though I understood the parameters but I have something wrong:
1. The control point I am using is my baseline alignent for crown
2. The insert point I figured I tie to a saw cut line alignment
3. The widening width to the eop alignment
All that looks good, But it does not appear to be reading the super elevation from the alignment (its been calculated) the section viewer is all default 2% through the curves. What did I do wrong?
Also, am I correct in thinking I need 2  assembly for left side and right?
Joe Bouza
5 REPLIES 5
sboon
in reply to: Joe-Bouza
I just tried it here with a tutorial drawing, and everything works fine for me.  Perhaps you calcuated the Inside Lane supers by mistake?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Joe-Bouza
in reply to: sboon
Thanks Steve, I'll giver her a look on Monday.
Joe Bouza
Joe-Bouza
in reply to: sboon
I checked my alignment super calc and it all looked good and the assembly seems to be reading the SE now.
Next question: what is the correct way to add a 4' shoulder and curbing? I set the shoulder calc to breakover removal on the low side and match slope on the hight side. I used a 4' OutSidesub and thought I should select the lane super in the props, but it matsched the lane cross slope. How do I get it to be 4% at NC?
Joe Bouza
Joe-Bouza
I hijacke my own thread. You cant. best bet create a transition profile
Joe Bouza
Joe-Bouza
Make sure the super is calculated
Joe Bouza
Rail Community
