Hello Everyone,
So a little background, I am using the overlay mill and level subassembly to generate contours for a mill and resurface. The style of the surface is .2 contours, im sure if I was using a higher contour interval the lines would smooth out but I have to use the .2 interval. What would be the best way to smooth these out? I have played around with many of the options in this subassembly and cant seem to generate smooth contours. I am debating to use a different subassembly and maybe just go with a superelevation one that I can use a profile so that I can manually tweak the gutters.
Nick
Solved by tcorey. Go to Solution.
Try increasing your Frequecies.
I tried that previously and bumped them up to about 2.5 feet but now after you suggested it, I went back and tried it again, all the way to .5' and it corrected the problem. I didnt think I would have to go that tight but I guess that makes the difference in this scenario. Thank you!
