Civil 3D Forum
Overall Parcel
16 REPLIES 16
Message 1 of 17
erwebsite
984 Views, 16 Replies
Overall Parcel
I thought you could create an overall parcel but, I can't figure out how. I have 21 parcels and I want one parcel that is all 21 together.
-John
Civil 3D 2014
Win 7
16 REPLIES 16
Message 2 of 17
wfberry
in reply to: erwebsite
Parcels are in Sites.  Make a new site and use that to make another single Parcel.
Bill
Message 3 of 17
Joe-Bouza
in reply to: wfberry
I'm confused?
Would not the overall parcel have been the parent of the subdivision? I did not know you could make parcels without subdividing?
Joe Bouza
Message 4 of 17
sboon
in reply to: Joe-Bouza
This is a situation where Civil3d does things differently than the real world.  Most of the time the lot that you own is a subdivision of the larger parcel that the developer started from, which is a further subdivision of a Section, which is part of a Township etc.  You may own the individual lot but the larger parcels continue to exist as a reference for the surveyors to work from.
The problem is that in C3d when you subdivide off a lot, that portion is removed from the larger parcel.
Steve
Expert Elite Alumnus
Message 5 of 17
Joe-Bouza
in reply to: sboon
Yes I am aware of that, I was confused the the OP got 21 parcels without subdividing.
Joe Bouza
Message 6 of 17
rl_jackson
in reply to: sboon
Can anyone say data shortcuts for parcels or someting similar?
Rick Jackson
Survey CAD Technician VI
Message 7 of 17
mathewkol
Not sure what you mean Joe. I can't see anywhere in the OP's post where it says he did not subdivide.
Anyway, it's easy to do. Just make parcels from interconnected linework.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 8 of 17
Joe-Bouza
in reply to: mathewkol
I wasn't thinking from objects. I couldn't figure out how to draw a parcel from the parcel tool bar? I see now fixed lines and curves can do it but it kinda clunky.
Joe Bouza
Message 9 of 17
When you create a bunch of parcels on a site, an overal parcel is automatically created that contains all of the connected "sub"-parcels. You can attach a label to it as you would any parcel. No need to use separate sites, etc. It's done automatically.
Message 10 of 17
jmayo-EE
You may want to look at keeping one file for the existing parcel and make another for the proposed parcels.
Use xref's to bring them all into you design files and sheet files.
John Mayo
Message 11 of 17
sboon
Are you sure abou that?  I'm looking at the Parcel-2C drawing from the Tutorials.  Toolspace says that there's only 11 parcels in the drawing and that matches what I see.  How do I get an label onto the overall parcel?
Steve
Message 12 of 17
jmayo-EE
in reply to: jmayo-EE
If the you want the total area labeled you also may just want an area label on the Site. Note this would assume the entire site only the one large existing parcel.
Do this in Prospector by expanding the Site tree and right click on Parcels. You can add an area label to the site in this dialog.
John Mayo
Message 13 of 17
erwebsite
Thanks I saw this and it works. Now I am trying to give the site parcel a different style that the individual style. Its not working like I thought it did before. The outer overall parcel should be able to have a style that is a different color but it doesn't seem to work. -John
Civil 3D 2014
Win 7
Message 14 of 17
in reply to: sboon
As johnm pointed out, right click on Parcels in the Prospector (under the appropriate Site), go to "Propoerties", and attach a Site area label style. (See attached file.) In the red oval, upper right corner, the label for the automatically created overall site appears. It is typically named Lot 0, and does not appear in the listing of Parcels.
Create a label to suit for the overall site, attach it via the Site Parcel Properties as described above, then crack a cold, frosty one, kick back, and proclaim to all what a freakin' genius you are.
Message 15 of 17
In the same place as you attached a label, you can create and attach parcel styles as well.
Message 16 of 17
sboon
Kudos for everybody !!
Steve
Message 17 of 17
jmayo-EE
Go back to the Site's parcel properties dialog. Assign the parcel style you want, hit the Apply button and then look at the list of Parcel Style Display Order and make sure the style assigned above is at the top of the list.
John Mayo
Rail Community
