AutoCAD Civil 3D General Discussion
*Expert Elite*
neilyj
Message 1 of 4 (244 Views)
Accepted Solution
Output Surfaces as XML files
244 Views, 3 Replies
10-26-2012 03:13 AM
Any XML outputs experts (or anyone who knows what is output)??
I need to export a DTM for use in another package which I previously did by Extracting the Triangles, Selecting the 3D faces & Wblocking to DXF for import to the other package.
The developers of the other package have introduced an XML import which I have been trying out but when the surface is imported into the other package via XML most (but not all) of the triangles honour the original 3D faces.
The question is therefore: Does the XML output contain sufficient information to allow the other package to "join the dots" in the correct way so as to mirror the original 3D faces and thus create an exact copy of the DTM??
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Distinguished Contributor
bingeomatics
Message 2 of 4 (222 Views)
Re: Output Surfaces as XML files
10-26-2012 11:31 AM in reply to: neilyj
I think LandXML format supports all informations for AutoCAD Civil objects, also Surface contains.
Binnat Khalilov
*Expert Elite*
neilyj
Message 3 of 4 (192 Views)
10-28-2012 02:17 AM in reply to: neilyj
i suppose it's easy enough to import the xml back and compare surface triangles
neilyj
bingeomatics
Message 4 of 4 (167 Views)
10-28-2012 11:05 PM in reply to: neilyj
yes it is.
Binnat Khalilov
Announcements
Need installation help?
