Civil 3D Forum
Output Surfaces as XML files
3 REPLIES 3
neilyj666
413 Views, 3 Replies
Any XML outputs experts (or anyone who knows what is output)??
I need to export a DTM for use in another package which I previously did by Extracting the Triangles, Selecting the 3D faces & Wblocking to DXF for import to the other package.
The developers of the other package have introduced an XML import which I have been trying out but when the surface is imported into the other package via XML most (but not all) of the triangles honour the original 3D faces.
The question is therefore: Does the XML output contain sufficient information to allow the other package to "join the dots" in the correct way so as to mirror the original 3D faces and thus create an exact copy of the DTM??
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
3 REPLIES 3
in reply to: neilyj666
I think LandXML format supports all informations for AutoCAD Civil objects, also Surface contains.
neilyj666
i suppose it's easy enough to import the xml back and compare surface triangles
yes it is.
Rail Community
