Civil 3D Forum
Out of memory - shutting down
17 REPLIES 17
Message 1 of 18
LyleHardin
23007 Views, 17 Replies
C3D 2013 crashed on me earlier today with the above error. I've submitted several Reports after the crashes. I've tried rebooting, repairing, re-installing, uninstalling and reinstalling with reboots in between. I have a presentation tomorrow and I need to fix my C3D drawings.  When trying to start C3D, as soon as the splash screen is gone, I get the "FATAL ERROR: Out of memory - shutting down" AutoCAD Error Aborting error.
C3D 2012 still works and AutoCAD 2013 works, but of course I can't edit my C3D objects.
I've just submitted a report and figured I'd post here as well.
Any clues?
17 REPLIES 17
Message 2 of 18
Sinc
in reply to: LyleHardin
What OS?  Are you on 64-bit?
Sinc
Message 3 of 18
Sinc
I also recommend that you DO NOT upgrade to 2013 at this point...  Too many bugs.
You may be encountering one of those.  It's especially bad to try upgrading a project just as you need to do an important presentation...  Stay on 2012.  Things might get better after 2013 SP1 is released, but I wouldn't be in a hurry to upgrade until then.
Sinc
Message 4 of 18
Sinc
in reply to: Sinc
There are plenty of bugs enough in 2012, such as the way the settings in the "Add Labels" palette often fail to appear; the way the "Recent Documents" list fails to work; the way that the Menu bar will appear overtying the Ribbon in a sort of "garbage" UI display (even thought the menu is turned off); the way that C3D will "lose focus" and go into "Not Responding" mode in a large variety of commands for no apparant reason; and a whole bunch of other problems.  But in general, C3D 2012 seems to work better than C3D 2013, even though C3D 2012 has TONS of problems that were never fixed.
Sinc
Message 5 of 18
If you can't track down a back up to run in 2012 then try the instructions in this article -
Resolving user specific issues by resetting AutoCAD Civil 3D 2013
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19170578&linkID=9240697
This should clean out all the settings stored in your user profile for civil 3d and when you start up civil 3d, a secondary installer should put in fressh files and settings.
If that doesn't work, and you still want civil 3d, search for removing all settings after uninstalling civil 3d to give you a clean install.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Message 6 of 18
LyleHardin
Got a response from Autodesk.
The reports I sent didn't clue them in, but they suggested the following:
1. Starting Windows in Diagnostics mode.
2. Loggin in as a different user.
I did not do the first thing (diagnostic mode) but did fire up Windows with a different user and it is working.
I plan on using this for now to finish my project for this afternoon's presentation. BTW, it is a small, but complex project with just a few drawings, all started in C3D2013 (not from 2012) and contains an aerial image, a few corridors and surfaces. It is 'just' a quick proposal and I'm using it as a test of 2013 and have had good luck so far. I like 2013.
I might try the diagnostics later this afternoon and let you know how that works.
Thanks for the responses.
System info:
Windows 7 64 bit.
HP Z400 with Solid State Hard drive, Xeon W3670 3.2 GHz, 24 GB RAM. Two ATI FirePro 4800 running 4 monitors.
Message 7 of 18
Certainly sounds like a broken setting in the civil 3d user registry or file areas which resetting the user setting to kick of the secondary installer should fix.
I have had similar issues with some users on 2010 and 2011 which was fixed by resetting the user settings.
Might be worth a look after you have your project sorted.
Andrew Puller
Civil 3d 2021
Message 8 of 18
Try deleting all the Cache Files in " c:\Users\<username>\AppData\Local\Autodesk\AutoCAD <product name>\R19.0\enu\GraphicsCache".  That solved the issue for me, but I am using ACA 2013.
Message 9 of 18
LyleHardin
That worked for me. I didn't think of getting rid of temp files.  That's one thing I recommend to my users when they are having problems...
Message 10 of 18
karlkarpuk
I just ran into the same problem in Civil 3D 2012
The problem arised after i created a certain feature line. The program crashed and closed. Now i cannot open this file again without the error. I can open all other files though.
I thought of trying to delete the aforementioned files but couldnt locate them even after using the search function.
After a year, has there appeared a better solution to fix the problem?
My whole project is in that one file that i don't have any copies of...
Message 11 of 18
AllenJessup
in reply to: karlkarpuk
You can try a partial open and don't open the layer that Feature line is on. Have you tried using Recover?
Allen Jessup
CAD Manager - Designer
Message 12 of 18
mathewkol
Also delete the Windows User Temp file...in Win Explorer go to %temp% and remove everything. The best time to do this is immediately following a restart.
May not help, but it's good to do anyway. This solves many problems and you just might get lucky.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 13 of 18
kalanaro
please what is that case ???
Message 14 of 18
troma
in reply to: kalanaro
Have you tried all the suggestions listed above?
Mark Green
Working on Civil 3D in Canada
Message 15 of 18
kalanaro
what should i do for that case ? i have 32 bit auto-cad architecture ... please i need help .
Message 16 of 18
this isn't the Autocad Architecture forum this is the Civil 3D forum
the autocad architecture forum is here: http://forums.autodesk.com/t5/autocad-architecture/ct-p/56
Message 17 of 18
LyleHardin
It's an old thread, but it appears deleting the temp files worked for me, even though I don't remember this happening at all.
In Windows Explorer, go to %temp% and delete all the files. It's a good idea to do this once in a while anyway. If it's never been done, you may get rid of over 5-10 Gig of files. Empty trash after that too. Someone suggested deleteing the temp Cache too. Give that a whirl. If all that fails, log in as someone else.
Message 18 of 18
mssaruhanli
thank you so much
Rail Community
