Okay,
So my co-worker says everytime he opens up a drawing, all of his osnaps are on. He turns them off and reopens the drawing, and they are back on. Before I go down stairs to see what the problem is, I thought I'd ask all you. Any thoughts?
F3...lol. Why would he want to use CAD w/o snaps?
Or in the Startup Suite.
Or in the MNL file associated with a CUIx.
@gccdaemon wrote:F3...lol. Why would he want to use CAD w/o snaps?
Personally, I despise running osnaps with a passion and I never use them. If I had a system that was constantly turning them back on, it would piss me off.
Now, with that said, I use snaps all the time and anyone using AutoCAD without snaps won't be using AutoCAD long, I just don't like the running osnaps.
A PC is doing a lot of needless work running drawing aids not being used.
I like them running for some tasks. 2d layout work I use end, mid, int. When I grade I leave only the endpoint osnap running but I never have them on all day. If I need a particluar snap not running I hit shift, right click and type the magic letter. I cycle osnaps, polar, otrack, dyn and quick props all day long everyday with the function keys or on the staus bar.
John Mayo
Ditto Brian.
And before someone asks why..........
Try snapping to an endpoint, or near point, or node with running snaps enabled, and purposly miss the pick, you get a point anyway. When you use object snap as a command modifier and miss the pick, your pick fails and you don't get a bogus point.
You guys are not helping me here. I have two PC's here at my office which one is setting snap to like endpoint, intersection, parallel, node, etc. It turns on about 6-7 of them. It also is turning off the Autosnap marker. The user will turn the snap marker back on and set osnap to just endpoint. He will save the drawing and get right back into the drawing and the settings are like before. Why is that?
T
I agree, it sounds like something is changing settings on drawing open, which you stated earlier on in the post. In the System tab under Options, try unchecking the "Load acad.lsp with every drawing" option. You might see it load with the default drawing that open, but you wouldn't see it when you manually open another drawing.
On the machine where this is happening, paste in the following (include the parenthesis)
(findfile "acad.lsp")
(findfile "acaddoc.lsp")
Note the location of these files and go to that location and temporarily rename/move/delete them so AutoCAD cannot find them. Restart AutoCAD. Any difference?
