Is there a setting that I am missing where if your osnap is set to node, it will snap to the node if you hover over the point text? I seem to remember this working in versions before 2012.
Increasing the Aperture Size in Options>Drafting Tab>Aperture Size will allow the
Point node to be snapped from further away when using the Node osnap.
Using the transparent command 'PO will let you snap to a node by hovering over the text.
Dave
Dave Stoll
Las Vegas, Nevada
Neither of these options do what I want it to do. I thought if you had Osnap set to NODE that you could hover over the point text and it would snap to the point node.
It did at one time. Maybe with a previous version of the Civil point object. I know it did in LDD.
While not an answer to your question. THIS can help while drawing using OSnaps.
Allen
Allen Jessup
CAD Manager - Designer
did you ever figure this out? im having that same issue LDD used to be so good now this is just frustrating.
if i increase apeture then its gonna snap to other stuff close to it.
if i increase the point node style size its going to clutter the screen.
cant hover over point labels anymore.
hopefully you found a solution. after all these years the simple stuff you think would be fixed by now. ORRRR they could have not even touched it from the beginning.
