Civil 3D Forum
Ortho image causing lines to print transparantly
5 REPLIES 5
asloat
363 Views, 5 Replies
In Civil3D 2012, I have used Data Connections to load one or more color ortho images. I have also added shape files using the same method. In these drawings I also may have regular CAD items such as Polylines.
When I print, both the lines from the shape files and the Polylines in CAD print out transparently on top of the Ortho image. The only way I have found to get either to print without transparency is to set them to black color.
Is there a way to get these things to print as solid colors on top of an Ortho image that is inserted with Data Connection?
5 REPLIES 5
Pointdump
in reply to: asloat
Asloat,
Have you tried Edit Style in the Display Manager?
http://help.autodesk.com/view/MAP/2015/ENU/?guid=GUID-76076D83-1490-45A3-9D82-3656C77C6EB2
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
asloat
in reply to: Pointdump
That link relates to the image data, not the shapefile data. Either way I have looked at styles for the raster and shapefile data and for the shapefiles I see no setting that controls transparency. It seems no matter the color,l unless it is black, it is transparent over a data connected image.
AllenJessup
in reply to: asloat
In the Plotter Configuration Editor make sure your lines are set to Overwrite not Merge.
Allen
Allen Jessup
CAD Manager - Designer
asloat
in reply to: AllenJessup
You sir, are correct. Thank you very much.
AllenJessup
in reply to: asloat
You're welcome. Luckily it was a problem I've had to contend with in the past.
Allen
Allen Jessup
Rail Community
