When I try to open drawings, the windows explorer dialog box doesn't appear anymore. The program expects me to enter the file name.
Solved by AllenJessup. Go to Solution.
Check FILEDIA is set to 1. While you're at it, check CMDDIA is also set to 1.
You can force the file dialog box to show by entering a tilde, a ~
Allen Jessup
CAD Manager - Designer
Thank you so much! The first command change solved the problem. Rich
Edited by
Discussion_Admin
Glad to help. That was an easy one.
Allen Jessup
