Civil 3D Forum
Opening drawing in Civil 3D 2013 and drawing view changes
7 REPLIES 7
Message 1 of 8
1171 Views, 7 Replies
Recently upgraded to Civil 3D 2013 and drawings opened up fine.  Now today any drawing that opens shows the plan view as last saved but then after loading takes the drawing and shifts it into a 3d view similar to a crossection.  Is there a setting somewhere that has been changed?  I noticed after a windows 7 update was preformed.  Thanks.
dwg ucs opening
7 REPLIES 7
Message 2 of 8
I think it is a known bug.
You can add "plan" to your acaddoc.lsp.  But that isn't always the desired result.  We did add the plan button to the Quick Access Toolbar.
In my opinion this has been the buggiest release in a long time, yet still no service pack.
Hope that helps,
Conan Witzel
Message 3 of 8
Seems to happen when switching from paper space to model space.
Message 4 of 8
Matt_Haokip
Hi Steve,
I belive the issue you reported have been fixed with the recent release of Civil 3D 2013 SP1. Please download the SP from the following link and let us know the outcome: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20980082&linkID=9240698
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Matt Haokip
Message 5 of 8
Service Pack 1 has fixed the issue.  Thanks.
Message 6 of 8
idigg-be
i installed 2013 less than a week ago(i assume it has this service pack), and it is still doing what is described above.  both when entering autocad and when going from a layout to a model tab.  i also noticed it resets ucsfollow to 1.
super annoying.
Message 7 of 8
Jeff_M
in reply to: idigg-be
Don't assume anything. If you know you told the installer to also install the Service Pack then it was installed. However, the SP was just released a week ago so there's a high probability it wasn't even available when you installed. Check the About screen to be sure:
Message 8 of 8
idigg-be
in reply to: Jeff_M
wow.  i assumed it had been out for a bit.  i dont have it.  thats annoying.  should have waited 3 days to install it.
thanks.
Rail Community
