It would be nice to be able to open an xref drawing directly from the sheet set manager. I envision right-clicking the sheet in the sheet set manager, then "open xref" that will populate a pull-down list of xref drawings within that sheet. This would save time from having to open a drawing and load all the xref's to select the xref one wants to open.
Solved by kcobabe. Go to Solution.
Ahhh, you must have not found the model views tab 😉
Yes sirie, and when you investigate how to drage and drop saved views youll start leveraging SSM even more
