C3D 2013 64 Bit, Win 7 Pro 64Bit
When I use the open command in C3D the file date is incorrect for a file.
I also have a explorer windows open and it shows the same file with the
currecnt date.
This file is located on my local hard drive.
C3D shows 11/15/2013 for the date the actual date of the
file is 11/26/2013. Even after a save it's still wrong.
My isavepercent is set to 0
Any Ideas?
Solved by wfberry. Go to Solution.
Check out the top column heading when opening the file. Right click and you can select "Date Modified", "Date Created", etc. This may be your problem.
Windows Explorer has the same type column headings.
Bill
Boy am I the idot here.
Who would have though the are 3 date colums
Date (Whatever that means)
Date Created
Date Modified
Quite a few more date options but these show up on 1st right click.
Problem Solved!!!!
