I've been working with some old drawings. I often get this message when I open one.
The problem is that if I chose to Temporarily convert them they'll still be there the next time I open the drawing. If I chose not to they're still there. It's tough to search a large drawing for all "large, dense" hatch patterns.
The solution I've come up with is to do the conversion and use Qselect to grab all the SOLID hatch patterns then wblock them out. Erase all those hatches, save the drawing, reopen the drawing and insert the Wblocked solid hatches.
I still get the message but it doesn't convert any more so I just select Don't Convert and check always use this choice.
Allen
Allen Jessup
CAD Manager - Designer
Solved by AllenJessup. Go to Solution.
I'm replying and selecting this as the answer because this is a tip and I don't want it escalated.
Allen
Allen Jessup
I've since found that if a post does get auto-escalated and I don't want it to be. I can go to the Subscription site and close the case.
Allen Jessup
