I have no idea what I hit by mistake, but suddenly I have a search tool and some kind of zoom control that affects the text of my command line.
It's in the way and I'd like to get rid of it. It's also pretty useless as a search tool because I can't find any way to actually type inside the box!
I have tried searching for info but as I don't know what the thing is called, I can't find anything. I tried the command line options and the search settings with no luck.
I'll attach a screen shot, with the thing marked out in red.
Can someone please tell me the variable or setting to remove it please?
Civil 3d 2015
PJ
Solved by rkmcswain. Go to Solution.
Thanks.
No add-ons but I do have a graphics card so it could be something to do with that, as you suggest.
Luckily, as with that other person, the inserted thing has now vanished by itself. I wish I knew what I had keyed so I can avoid doing it ever again.
Oh well, it's back to normal now.
Thanks again.
PJ
Weird!
I have found the click combination that makes this pop into existance, but repeating the combination doesn't get rid of it. Closing and restarting Cad is the only way that I have found to remove it.
I don't know the right term for the bit of text that appears above the command line and shows your previous commands, but if I click on that bit and then hit f3, the useless search and zoom tools appear.
PJ
