Civil 3D Forum
on/off display toggle for surface points and triangles - how to do this?
4 REPLIES 4
caddie99
1059 Views, 4 Replies
Since Action recorder does not work with the surface style display box, is there any way
to automate the toggle of points and triangles display ?
I dont see any command lines that can change the light bulb status?
using c3d 2012
4 REPLIES 4
Jeff_M
in reply to: caddie99
Use different styles and swap the style used.
caddie99
in reply to: Jeff_M
what is the command line to do this?
if it involves dialog boxes it wont save any time
Jeff_M
Once you have the styles. Setup you can switch styles on the properties or quick properties palettes.
caddie99
in reply to: Jeff_M
Thank you..... much better
Rail Community
