Hi guys,
I got a drawing with an XREF attached that I want plotted faded so I use plot transparency. I also have an OLE object (Excel table) in my paperspace which for some reason plots as a negative (white text on a black background instead of vice versa). If I turn the plot transparency off the table prints correctly but the XREF is not faded. Any ideas what might help ? Thanks.
I gave up trying and printed the table to pdf and attached the .pdf which plots fine. I am just curious why the original way doesn't work
Because OLE have an inherint limitation in ACAd which includes plotting.
http://forums.autodesk.com/t5/Printing-and-Plotting/HP-DesignJet-Problems/td-p/275950
