I have a centerline alignment with two offset alignments that reference it (road edge). At the curves throughout the 3+ mile segment I manually added widening to the offset alignments at the curves. I now need to go back and add additional curves to the centerline alignment. I'm trying to do this by adding additional PI's to create a new tangent where I want the curve, then deleting this tangent and adding in the new curve. When I delete the new tangent sub entity my offset alignments get cut off at end of the alignment (where I deleted the tangent). This causes all of the widenings I had created to be bunched up at the section of remaining CL Alignment. When I build a new curve through the deleted portion and re-establish the alignment to its full original length the offset widenings do not re-associate to their original stationing (they remain bunched up at the first few hundred feet.
Is there a way to add curves to the alignment without losing the stationing for my curve widening on the offset alignments? I attached a screenshot of what happens to my offsets (red) when I delete a section of the CL alignment, the widening remains all bunched up when I reconnect the original alignment.
Solved by toyhonda86. Go to Solution.
Don't delete the tangent, use Free Curve Fillet and select the two entities you want to fillet then enter the radius.
Thanks Adam, figured this out just a few minutes ago. Overthinkg it as usual!
