I opened up and existing draing with alignments and offset alignments to make some edits but when I edit the main alignment the offset alignments do not update dynamically. The only way I can update them is go into properties, make them static and Apply , then make then dynamic and Apply.
Any one come across this or got any suggestions as it's a right PITA doing this for every edit......
neilyj (No connection with Autodesk other than using the products in the real world)
Hi Neal,
What version of Civil 3D are you having this issue with? Any Service Packs installed? Do you have other Alignment Offset drawings where this is a problem? Meaning is this common, or only seems to be this one drawing?
It's in 2015 SP1 but it only seems to be this particular drawing that is affected (I have tried a new dwg from template and offset alignment works as expected)
I would normally have just deleted the offset alignment and recreated but it had a lot of widenings etc which I didn't want to have to recreate so I have just applied my Static/Dynamic workaround as this particular project is just about completed.
2016 SP2.
Got a drawing with the same problem. Annoying has hell ideas.
@ceethreedee.com wrote:
2016 SP2.
It appears to have something to do with the design criteria-- although I'm not sure what that something is.
After I opened your file, I was getting messages about "unable to locate design criteria file" whenever I tried opening the alignment properties. Then I changed two of the mainline alignments via gripedit (MC21 and MC22). The offset that is a child of MC21 updated fine. When I gripedited MC22, the child DID NOT update.
Then I re-opend the file (without any changes) and changed the child to Static. I was greeted with the following message.
I pressed ok and then changed it back to dynamic again. Now that the child is dynamic again, it DOES update when I gripedit MC22.
Here's what it looks like after I grip edit MC22.
Don Ireland
Engineering Design Technician
I am having this issue as well in Civil 3D 2017. Just started happening out of the blue. Don't get the criteria dialog box either.
Any ideas?
Thanks a lot.
-Seth Cohen
Joe Bouza
Hi Joe,
Thanks so much for responding! Yes, very frustrating, especially when your showing your boss the alignment for him to check, and he says, that transition looks off :-).
Thanks.
- Seth Cohen
Not just frustrating, this completely fails the whole reason for using offset alignments.
Doing the Static + apply Dynamic + apply catches them up to the original alignment, but they basically stay static.
When I adjust the alignment again, have to go through that routine all over for each offset. Aaaaarrrrgh
I've created a new drawing, and they work great, just like they're supposed to.
C3D 2016 service pack 1. Heartwarming to know it's doing this for no reason in 2017 as well.
I sound like a ranter.
Looking forward to ( hoping for ) a solution.
Thanks for letting me vent
Doug
Having the same issue myself....very frustrating....is there any answer out there on this yet..? Looks like another old thread with no resolution..... grr.
Frustrating to see that this issue is still happening in Civil 3D 2020......
Same issue still occurring in 2021...this would save so much time if I weren't constantly having to troubleshoot why it randomly doesn't want to work...
Same thing in C3D 2022. Altough I use referenced alignments as centerline but still have to manually click to static and back to dynamic to update the offset alignments.
Same on C3D 20233,drawing started on C3D 2020 worked on 2022(I am not sure when the links "broke"
Not just the alignments but linked profiles are not updating.
offset Alignment/profile Properties trough Prospector tab, shows the "linked Parent" alignment and profile, All Dynamic Linked (as supposed to be) but they don't follow the parents..
I wish there is a fix, to "RELINK" to parents, because to recreate all site with quite a few intersecting roads, and then surfaces that are linked into other models is quite a work.
The strange thing is that I tried deleting the offset alignments on one of the existing road, Then keeping the parent alignment I created new offset alignments with linked Offset Profiles in the profile view .
And they draw well but are not linked.. They don't update if I change parents..
Then I created New (test) alignment from start, Created Profile, then Offset alignment and linked profiles, and the result is the same. No matter shows as Dynamic, They don't update if I change the parent alignment or Parent profile.
By the way, I did Purge and Audit the drawings(Audit reported no errors) .
But there has to be something wrong with the drawing..
After my previous posting about my problem and try that did not work, I tried following a suggestions from Autodesk Knowledge base:
First suggestion to Insert the "damaged" drawing into new blank template, did not work, It crushes during the process with Fatal Error message. I tried at least 5 times.
Then I tried second (alternative) suggestion using WBLOCK command from the damaged drawing, and on Select objects I used Ctrl+A( for select all) so I selected all objects even hidden or layers off, including surfaces that are not displayed,
*** Note If you use select cross window I am not sure if will bring all objects across..
And Using WBLOCK command WORKED...Voala..
It brought all surfaces of different roads and linked Ground surface.
All corridors, alignments, sites, profiles, Everything I can think of except the Fault of the original drawing.
And the Offset alignments and linked profiles are working now. So I don't have to redo everything.
I still need to check that everything is fine , But so far looks good!
Please Comment if this worked for you too!!
Thanks for posting the link to the knowledge article! To bad this is still an issue after what 7 new releases. Maybe I'll have to give it a try again...currently just using a combination of curb return feature lines with relative elevations and intersection tool just for centerline alignment and profile locking.
Like I mentioned in my earlier post, It worked for me using WBLOCK , The Offset alignments and the connected offset profiles are now linked to their parent Alignment and Profile(This is on all 10 roads I had on my site) .
But, My Long sections lost the bands assigned profiles labels in the bands, It added something like : OLD DESIGN (profile name) to the Profile View definitions.
The rest profiles were still on the list, but the bands data was not populating(see attached images)..
I am not sure which template WBLOCK was using but I also I had to reinsert from my Template the custom band styles and band sets and reassign the applicable profiles).. Once reinserted and overwritten the bands were populated correctly.
By the way, This method brough across all design sites ,Alignments, Profiles, Assemblies, corridors, surfaces etc, Including Linked surfaces. Just styles were missing as I said..
Still Minor inconvenience comparing to recreate whole road network with intersections ..
