I have created a widening then created an 11-foot offset from the widening for some reason I cannot create a 22-foot offset or an d11-foot from the first offset. I can go as high as 22.5 but no more. There are no curves in the alignment only linear tapers. Any ideas why I cant get to 22-feet?
Your Name
Your Name
Solved by jmayo-EE. Go to Solution.
Your Name
Your Name
the first thing that comes to mind is that one of the user specified inputs causes a condition that cannot be solved at the offset requested. is there a way for you to check this other than tweaking them a bit and seeing what happens.
I do not have a bunch of experience with tapers and widenings so I am reaching a bit here. Just thought I might think out loud for a bit and maybe you would have a light bulb moment.
Your Name
Your Name
Your Name
Your Name
Your Name
Your Name
Your Name
Your Name
Your Name
Your Name
yup.
asking the impossible usually is the culprit LOL.
Now if the software would only tell us so.
Doesn't even have to be nice about it as far as I'm concerned.
"Are you freaking kidding me" would suffice.
