AutoCAD Civil 3D General Discussion
lambertb
Message 1 of 5 (644 Views)
offset alignment as pavement edgeline
644 Views, 4 Replies
01-15-2014 01:01 PM
civil 3d 2014 sp1
I would like to use offset alignments for my edgelines. I have come across two ideas.
1. put the o/s alignments in the same dwg as the centerline alignment. DS into a proposed work file.
2. DS centerline into a proposed work file, create o/s alignments there.
You can use the intersection tool to make alignments in either the centerline or proposed work file. However profiles are in the alignment file and only would be linked there.
Data management of civil 3d files could be a full time job...
Thanks.
C3D 2014 SP1, Windows 7 Enterprise 64-bit
Dell T3500 workstation, too much ram to post
*Expert Elite*
Joe-Bouza
Message 2 of 5 (621 Views)
Re: offset alignment as pavement edgeline
01-15-2014 03:27 PM in reply to: lambertb
not sure if there is a question here but cant you just use a alignment to target and profile?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
lambertb
Message 3 of 5 (600 Views)
01-16-2014 01:48 PM in reply to: Joe-Bouza
I was wondering if anyone has workflow experience of putting edge of pavement alignments in with the centerline or if they put them in a proposed work type file. We are starting out new to civil 3d and are trying to find tips and tricks for data management. With multiple users on a project, keeping multiple people accessing different design areas is a bit tricky without having one dwg for every c3d object...
ericvallejo7526
Message 4 of 5 (594 Views)
01-16-2014 02:06 PM in reply to: lambertb
Coming up with a Civil 3D workflow starting out is definatly a challenge for any firm.  It took a while (years) for us to get a drawing management workflow established through many aches and pains.  I just posted something along the lines yesterday concerning this, along with an example.  Check it out; hope it helps you get going!
http://forums.autodesk.com/autodesk/board/message?board.id=66&message.id=238992#M238992
Eric Vallejo, LSI
Missman, Inc.
Civil 3D 2014, SP2
Windows 7 Professional, 64-bit
*Expert Elite*
Joe-Bouza
Message 5 of 5 (587 Views)
01-16-2014 02:19 PM in reply to: lambertb
yes it can be tricky.
I wish I had a clear answer. I'm mostly working on my own or with 2 or 3 others so corrdinating has not been a big deal yet
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Announcements
Need installation help?
