For some reason, when I view my corridor in Realistic mode in object viewer, all the rendering has changed colours and quality of the textures etc.
It used to display just fine and I am wondering what has caused this? Is it a Driver issue? Any ideas?
I have attached an image of what it looks like now. As you can see the quality is really poor and the colours are wrong.
Any suggestion will be appreciated. Thanks.
You may want to check for your graphic card and drivers and make sure it is up to date. Further, try viewing the same file on another system or log into your system with a different user profile and if the issue is specific to your profile, you may want to reset your user settings following the steps provided in the link:http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18353335&linkID=9240697
