Hi everyone
When i look at my corridor in object viewer i see points around corridor as you see in the picture.I am wondering what are these points, is there an option to hide them and is there additional display option to select which objects are going to be displayed in object viewer?
Solved by Umit.Arslan. Go to Solution.
It looks like you also have a surface in the object viewer with a style that only displays points in the model view direction.
I can't verify this right now. But if your corridor targets the surface. It may select that also. If that's so. Try setting the surface to a style that doesn't display anything in Model.
Allen
Allen Jessup
Engineering Specialist / CAD Manager
Finally i solved the problem.It is my assembly created by SAC.I put auxiliary surface link in the assembly and Civil 3d is attempting to show these points as uncodeded points in the code set style.I hope this post will help someone in time 🙂
