Civil 3D Forum
Object Viewer Pivot Point...?
5 REPLIES 5
kaanturkum
2151 Views, 5 Replies
  Hi Everyoe,
I have some objects (corridor / intersection corridor / surface / grading ...)  in civil 3d 2013
When we rotate the 3d objects , object rotate pivot point  about (0,0,0,   or any place x,y,(z=0)
So rotated 3d object (if the Z= High value)  can't be seen / can be seen as a point.
how to change the object viewer pivot point ?
(not using steering wheel or zoom extents  because of first time rotating objects seen so far )
5 REPLIES 5
AlmasSuljevic
in reply to: kaanturkum
Hi kaanturkum,
I personally am not sure about the question. Can you elaborate a bit more and perhaps post your image or drawing for others to see?
The only thing that comes to mind is Set View settings or Constrained 3D Orbit in Object Viewer (icons) that may be causing something similar.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
jmayo-EE
Enter the 3dorbit command. Right click and confirm  your settings with the attached. I think Autotarget and contrained orbit are what you need.
John Mayo
iturgeon
in reply to: jmayo-EE
Yes. 3dorbit works for this, but why doesn't it work in the event viewer. The advantage to the EV is that you aren't actually manipulating your view, just inspecting it, once you leave the viewer, your view is unchanged. Not the case for 3dorbit, which actually changes your current view. Requiring an undo, which seems to have taken a hit in terms of stability over the last few releases. Some lazy programming going on, in any case, the event viewer pivot, used to work.
kboldt
I know I'm digging up an old thread here, but I was having this same problem, and found a bit of a solution.
If I go into Object Viewer, and start orbiting around a surface and it seems like the pivot point is way off in no mans land, what I have found to work is, after orbiting any amount, I click "Top" on the view cube to reset the view, and then magically, it seems to be orbiting around the actual surface.
lynn_zhang
in reply to: kboldt
Hello @kboldt
Glad to hear you found a solution to fix the problem and thanks for sharing it here! Worth digging up the old thread!😄
Lynn Zhang
Rail Community
