hey,
Just noticed this lately - last week or so. I am working with a drawing heavy in Map objects - Acad objects with Map object data attached. I don't think this makes a diff, since it is not the first dwg like this I have spent tons of time with, but it is what it is.
I noticed for some reason, especially with ENDPOINT, that the osnap won't turn off. I can turn it off using OSMODE (via middle mouse button) or F3, but it doesn't make any difference - it still snaps to endpoints. I have also noticed it with nodes, but not as much.
I've been using Acad and LDT-->Civil 3d for around 15 years, and I have never seen this before. but, I know how to use the commands to turn it on/off.
I am running no lisp, ARX or VBA routines other than what comes out of the Civil 3D box (including Map).
I am thinking maybe a repair of the installation is in order? ANyone seen this before?
THANKS
david
Check your settings for short cut keys T&5, they have been known to interfere with real *ork.
not sure what these short cut keys are for, but I haven't enabled anything. it is strictly an out of the box install, except for a few toolbar buttons I have used for several years.
thanks
For what it's worth, I notice that working in Model Space through a Paper Space viewport the Osnaps work fine. Could this be a video thing? I have an NVIDIA Quadro FX 1800M (1MB memory?) in a Dell Precision, seven-core, 8MB RAM, Windows 7 64 Bit.
Just ran into this today. Even with Osnaps turned off, I was still snapping to certain objects.
It's 3DOSNAP. I must of accidentally hit F4 and turned it on.
Hope this helps.
Jonathan Stewart
