Is there a way to count all types of object in a drawing?
Like this:
Command: ????
Number of blocks: 22
Number of 3d faces: 2
Number of hatches:1
"Qselect" does it but it can be very slow if there are a large number of objects in the file.
I guess this information is savea as "meta data" and can be accessed even without opening the file???
Ctrl + A
Then go to your properties (Ctrl + 1)
Drop down the list at the top, it numbers each object.
Not great for a huge drawing maybe, but it's something like what you wanted.
Mark Green
Working on Civil 3D in Canada
If I were you I would have a look over at the lisp forum or just on the web with your favourite search engine. I'd be surprised if it hasn't been done before.
Mark Green
Have you tried SSX or a similar lisp or VBA. They will tell you how many instances of a block are found, including how may are not in the currrent space.
Surveyor Lee
