Civil 3D Forum
Object information to object geometry
4 REPLIES 4
csevers
2408 Views, 4 Replies
I'm making a surface out of contours. The problem is the contours have the elevation listed under object information, not geometry (the contours were brought in from a GIS file, which I do not have access to, or I would bring them in again with the elevations properly assigned, this is not an option). How can I quickly change the geometry elevation property to match the miscellaneous property?
Chris Severs, PE
Windows 7 Enterprise SP1 64 bit
64.0 GB RAM
Intel Xeon E5-2650 v3 @ 2.30GHz
NVIDA Quadro M4000
Civil 3D 2014
4 REPLIES 4
Neilw_05
in reply to: csevers
The old school method is to use a Map Query. The way it works is you set up a blank dwg, attach the source file with the contours and configure an Alter Properties query to apply the elevation field to elevate the contours. It's a bit too detailed to spell it out step by step here but I am sure there are several posts and blogs about how to do this.
Try searching for Map+contour+elevations
P.S. Though you don't have the original GIS files, you can always export to a shapefile and re-Import using the proper settings to elevate the contours. You might also look into the extensions for C3D, one of which is a tool for creating a surface from GIS files.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
thepworth
see the attached - what you want is a minor variation of something I posted for another user around the start of the year.
start a new drawing.  attach the first drawing with the contours with object data.  use drawing query & alter properties during query to adjust to elevation.
update the posting if you need clarification, or mark as "accepted as solution"
Cheers!
Murph_Map
You can always export the contours lines out to SHP format and create the attributes needed from the OD. Then use the create surface from GIS data tool.  No need to do a map attach and query in a blank dwg.
Murph
Supporting the troops daily.
neilyj666
in reply to: Murph_Map
Other options are to use the 2D to 3D contours Conversion tool in the UKIE pack or download the Sincpac (free edition) and use the ElevatePolylines (CHELEV) command (this give more options than the first mentioned)
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Rail Community
