I am having a problem with a drawing created with Civil 3D 2013.
We are a small surveying company and work for our city government; we do not use Civil 3D, but use Carlson Survey 2013 Embedded AutoCAD. The city has Civil 3D and saved a drawing for our use containing water lines, sewer lines, sewer manholes, etc. I cannot wblock or copyclip anything from this drawing. I have tried exploding each layer, still nothing will wblock. I searched on-line to find object enablers for the Civil program, only finding plant or architectural enablers. We need to use this CAD file. Do you have any suggestions how I can get rid of the objects linked to the linework/symbols? We need this file!
If all you're after is a "dumb" AutoCad file ask them to "Export to AutoCad" for you which converts the C3d objects to AutoCad primitives. If you need any of the intelligence ask them to Export LandXML so you can then import the data for use.
If you still need the Civil Object Enabler, you can download it here...
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19052749&linkID=9240618
