I have note labels in one drawing. An Elevation style that list the elevation of the insertion point. The label texts are dragged to new locations. When I xref this drawing in to another. The label text shows at both the insertion points and the dragged locations. What's going on??
I've made sure the labels aren't duplicated on another layer. If I change the layer of the dragged text and do an Xlist in the drawing they're xrefed in to. The dragged text list on the layer I've change it to. The text in the original position lists on layer 0, which is the default layer for creation.
Allen
C3D 2012
Dell T7400, 4GB RAM, Win 7 64 bit
Nvidia Quadro 4600
Allen Jessup
CAD Manager - Designer
Solved by jmayo-EE. Go to Solution.
Sounds like a defect if audit or recover don't fix it. Send it to subscription support if you can.
John Mayo
I've become leary of Audit. It's thrashed a few surfaces on me. I'll try it as a last resort.
Allen
Allen Jessup
I had to go the Audit route. Even after erasing the labels the ghost ones still showed in the Xref. After an Audit the labels appeared and could be erased. The only think I've seen, so far, that the Audit broke is a Hide Boundary in my existing Surface.
Allen
Allen Jessup
I feel the pain but also feel lucky. I haven't seen audit mess up my files since the 09 version.
John Mayo
I think I figured it out.
When you imported survey data, you may have imported points from several different files.
One file might have had pts 1-50, the next file might have had pts 1-100.
(All points from the same job)
If you imported points from both files, you may have duplicates of points 1-50 IN the drawing.
So if you drag the label for point 1, it will show up in a dragged state, but the duplicate for point one will be right underneath it in it's original state.
You can figure out if you have duplicates of the same point by dragging the same label out over and over again.
If you have three duplicates of the same point, you shouldn't see the label in it's original state after dragging the label three different times.
Hope that helps.
