Dear Friends,
I'm not getting the design levels of assembly, just major offset and elevation, how can i get all design levels from where my assembly is changing and where it is matching to the existing surface, is there any band problem or anything else please help me to solve this problem, im sending the view that how i'm getting my cross section and also i want to know that how can i control text size because it is too big for sections.
The section view labels are controlled by the Code Set Style used.
Open the following tutorial as an example and select the section annotation>Rt. Cilck>choose Edit Code Set Style>
C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2014\Help\Civil Tutorials\Drawings\Sections-Grade-Label.dwg
On the Codes Tab review the "Link" and "Point" labels being used and decide from here which labels are important for your projects.
Not sure which text size is too large? The answer on where they are changed depends on which text you wish to make smaller.
In short your caption includes the following styles:
-Section View Style
-Band Style (these include various Section View band styles)
-Code Set Style (these include Multipurpose Styles) found under the General>Multipurpose Style category.
Dear Jay_B I want to get my section like this with all existing & design levels, I'm sending you a screen shot and please tell me the image procedure how to get this style by unsing C3D 2010 version, because I don't have 2014 version. That is why I didn't get that dwg and procedure you told me.
Looking forward to your reply
Regards.
I don't know how to have or create band style sets to show the baseline & grade change labels, please can you explain me how to have or create this label style in details.
I suggest you check out the tutorials that come with the software, and do some search in this forum.
Search the forum for editing band styles
I'm not try to be rude but this has all been covered here before.
