Eliseo,
Sadly but truly the BPNR functions are gone :(. Like you I have a use for BPNR that is different from what others had used it for and also different from what some refer to as the original intent. No matter how you try to explain something like this you will most likely get the same answer(s) over and over. FYI, I submitted a C3D wish to AUGI some time ago (Oct '07) requesting BPNR functionality in C3D. I recently received a reply via e-mail requesting additional information, which I happily sent to them. I'm am by no means expecting this to fly, since I can not even find the "wish" anywhere on their website. Bottom line is, for Autodesk to implement something such as BPNR in C3D would like Trying to design C3D from the ground up (again). Could you imagine the problems the development team would have to sort through, all the new annotative text, annotative dimensions, viewport scale, plot scale, paper scale, C3D styles................ What a task it would be. All I want to do is do is be able to work with lengthy corridors (that do not run north-south) with it displayed horizontally across my screen along with the profile view above/below it. Forget abut using PS to do this, just is not the same, sigh !
ACADuser
(2) Dual Core Xeon 3.20GHz (1066MHz FSB)
2GB RAM
Quadro FX 3450/4000 SDI (256MB)
80GB 10,000 RPM HD
Dual Sony 23" Widescreen TFT
XP PRO SP2
With a bunch of 2008 Autodesk products
ACADuser
Civil 3D 2018, Raster Design 2018
Windows 7 Enterprise
Dell Precision 5810 Workstation
Intel Xeon E5-1630 v3 @ 3.70GHz
32GB RAM, NVIDIA Quadro K2200 4 GB GDDR5
DUAL 27" Dell UltraSharp U2713HM
