Member
MurraySimon8160
Message 1 of 6 (2,069 Views)
North Arrow Alignment with Plan Production
2069 Views, 5 Replies
01-31-2011 05:31 AM
I'm using the Plan Production tools to create alignment drawings and when adding the north arrow during the process i get a error at the end stating @unable to align north arrow?
North arrow is a block and tried with basepoint and alignment parameters, unless i have missed something in the block creatation?
How do i create a north arrow block that will align with the layouts in plan production?
Is your north arrow placed over the Plan viewport in the template you're using?
Lisa
Joe-Bouza
Message 2 of 6 (2,060 Views)
Re: North Arrow Alignment with Plan Production
01-31-2011 06:15 AM in reply to: MurraySimon8160
Only a guess: Does your block definition point straight up? Perhaps if you edit an existing block and replace the entities wiith yours?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Member
MurraySimon8160
Message 3 of 6 (2,051 Views)
01-31-2011 06:48 AM in reply to: MurraySimon8160
Yes the north arrow in the block does point straight or the top of the screen. Is there something that needs to be set in the block parameters?
Can someone send me a Nth Block that works?
Joe-Bouza
Message 4 of 6 (2,012 Views)
01-31-2011 05:20 PM in reply to: MurraySimon8160
I don't think it needs to be a dyno block, I use the old softdesk north arrow that been around for eons, and it works fine. Think about it, why would you want t o grip rotate you NA after PP did it for you :smileywink:
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
LisaPohlmeyer
Message 5 of 6 (1,984 Views)
02-01-2011 08:54 AM in reply to: MurraySimon8160
Lisa
Lisa Pohlmeyer
C3D 2012 SP4, C3D 2015
Please use "Accept as Solution" if this solved your issue.
teesoy
Message 6 of 6 (725 Views)
07-25-2013 10:28 AM in reply to: LisaPohlmeyer
We have had the same issue uisng Civil 3D 2012. The first few sheets are correct, but then the north arrow can get way off, depending on the range of directional change of the alignment. We are looking for a solution as well. I am going to try moving the arrow above the viewport layout in my template file as you say, but I don't think it is going to work just knowing that the arrow IS rotating in the process, just rotating incorrectly...
