Is it possible to create C3D labels that are non-associative? That is, they do not adjust font size, etc., with changes in viewport scale.
Thanks.
C3D 2014
Only way I know is to explode them once, of course then it's no longer a label and the contents will not update either.
I'll be watching to see if someone else comes up with something.....
Mark Green
Working on Civil 3D in Canada
Mark Green
Is there a way to maintain the text height in model space independent of the viewport scale?
Let's say I wanted the text in my label to remain a 4.8 foot text height in model space regardless of what the viewport scale is set to? In my current situation it doesn't matter if the text height in paper space is inconsistant from viewport to viewport.
Change the text properties from associative to something else - such as Standard.
Am curious why you "wouldn't" use associative text size?
@Anonymous wrote:Is there a way to maintain the text height in model space independent of the viewport scale?
Same question as OP? Check out the answer I posted. Does that work for you?
Mark Green
@ericcollins6932 wrote:Change the text properties from associative to something else - such as Standard.
The OP is talking about C3D labels, I believe. I think you are talking about Annotative Text.
Mark Green
I am referring to C3D labels as well. Such as structure labels, line labels, etc. I guess i should have made that clear in my post. I am setting up a few exhibits, and don't want my C3D labels to become giant in the viewport. Because of the company and client standards/requirements, I have to use background mask for my labels. When the labels become 2 times the size in a 60 scale viewport compared to the 30 scale viewport they were original designed for, there is information that gets "masked" that i need present in the exhibit. I know i can accomplish this with xref, data refs, multiple styles, layers, etc. That just seem a little too involved for such a simple function. Keeping the text in a label the same size regardless of viewport scale doesn't not seem like an unreasonable request.
Mark, look at what troma suggested. I have used that procedure before and it works well for what you're trying to do.
Tim
Mark Green
I tried the drawing scale conversion expression posted, but it did not perform the functionality needed. 4.8 divided by 60 is .08, this basically mimics the native behavior of the labels. It didn't seem to behave any different than if i just put .08 as the text height in the style. To clearify my goal (which i realize may not be possible) lets set up a hypothetical. Lets say we have two viewports side by side. One at 60 scale and one at 100 scale. I want the label in the 60 scale viewport to appear at .08 height in paperspace as it appears through the viewport. In the 100 scale viewport i want the label to appear at .048 text height. Which is basically keeping the text height at 4.8 feet in model space regardless of what scale the viewport is at. I have only scratched the surface when it comes to expressions, is this something that would be possible with an expression? From the little i know about them it doesn't seem possible. The label reads the viewport scale somehow, so it would be nice if we had the ability to access that data in an expression similar to the "drawing scale conversion". Instead make it "Viewport scale conversion" and the posted expression above would work perfectly. Then i would be able to set up an expression that sets text height based on viewport scale instead of drawing scale. Right now i have been creating a new style and a new layer for the alternate scale labels, which gets the task accomplished. I was just hoping to improve the process a little.
Mark Green
Troma: Your solution worked perfectly as far as keeping the font size non-associative through various viewport scales. However, the gap for spacing the border remains "associative" in that it changes with various viewport scales, making the whole effect a little odd.
Any way to solve this part of the problem?
Jerry
C3D 2014
It's not often I need a non-associative C3D label, but an example would be parcel labels for individual lots in a large subdivision. At zoomed in levels they look fine, but zoomed out to show the entire subdivision the labels become so large relative to the lots that they overwhelm the view.
Mark Green
