Civil 3D Forum
Node Osnap in C3D broken
4 REPLIES 4
lhampton
410 Views, 4 Replies
Back in LDT you used to be able to mouse over point descriptions of draged state points to get Osnap to select the node. Civil 3D has apparently done away with this, why who knows but its very very hard to know what point your selecting if say you have a bunch of points on top of eachother. Can this be enabled anywhere?
The very mundain work around is to use 'PO to select the point entity, but it does not show the little osnap indicator on the point marker when you use 'PO.
How can I get my old Osnap node selection back?
Intel i7 2600 /z68 Gigabyte
8gigs DDR3 1800
Intel 320 Series SSD
Quadro 600 (1gig)
C3D 2016 / LDT 2009 / Win7 x64
4 REPLIES 4
jmayo-EE
in reply to: lhampton
Snapping to a C3D Point using the Node osnap should work. If explode and destroy the C3D point you now have Autocad blocks representing your point so you will need to use the Insert Osnap.
John Mayo
lhampton
in reply to: jmayo-EE
" If explode and destroy the C3D point you now have Autocad blocks representing your point so you will need to use the Insert Osnap."
Makes no sense... what are you trying to say here
8gigs DDR3 1800
Quadro 600 (1gig)
AllenJessup
This is a thread about this topic that was started on Monday. It lists some options. But not the exact method you want. Although if there is enough interest it may appear again some time in the future. The only option you'd have to get it back quickly would be to find a 3rd party that provided it or pay a 3rd party developer to do it.
Allen
Allen Jessup
CAD Manager - Designer
jmayo-EE
" If you explode and destroy the C3D point you now have Autocad blocks representing your point so you will need to use the Insert Osnap."
John Mayo
Rail Community
