Civil 3D Forum
no point file format match found
11 REPLIES 11
Message 1 of 12
13412 Views, 11 Replies
english is not my first language, so i wil ltry to explain the best i can my problem.
i made a survey, about 2000 points with my TSC3\R6. I exported my CSV file to a PNEZD file with comma seperated. When i try ti import the file (CSV then i made a .txt), C3D tells me "no point file format match found". Then I opened the txt file, searched for any error that would not let me import my points. The only thing i have found would be the description of my points that sometimes had a space between 2 words (ex: bt balast and ht balast) so i changed it to bt-balast and ht-balast. i looked further and didnt found anything else. heres a sample of my txt file:
11251,5038721.804,370118.600,52.877,69
11252,5038722.437,370118.327,52.980,82
11253,5038725.381,370117.058,54.235,81
11254,5038725.967,370117.395,54.325,bt-balast
11255,5038727.637,370116.899,54.860,ht-balast
11256,5038728.983,370116.602,54.857,balast
11257,5038730.043,370116.150,54.839,ht-balast
11258,5038731.524,370115.635,54.345,bt-balast
11259,5038731.763,370115.674,54.308,81
11260,5038733.529,370114.961,53.606,82
11261,5038734.460,370114.525,53.505,350
Now i have to draw something but i cant even find why importing points fails in C3D.
some usefull informations maybe:
windows 7 32bits SP1
autocad civil 3d 2013 (not yet activated, next week)
thanks
simon
11 REPLIES 11
Message 2 of 12
Sinc
Is your CSV file open in Excel...?  That will cause the failure you're describing.  Pretty annoying, especially since the error message is so vague, but that's how I hit that message.
Sinc
Message 3 of 12
antoniovinci
Please attach here your .CSV file, so we may run through it.
Message 4 of 12
fritzbone
I would leave it as a .csv file to import it. Also I would ensure there are no column headers in the file.
Message 5 of 12
in reply to: Sinc
Simple, yet outstanding answer.  You just saved me a silly waste of time.  Thanks for the post!
Message 6 of 12
IamAwefulatCAD
Why am I getting a no point file match found message when I try to import the below point file? I do not have the excel file open when I try to import. I see that there is a pre made point file format that matches my point file. I have tried creating my own point file format also. I have tried restarting and saving my .csv in diffent formats. I usually figure problems like this out on my own, but I have already wasted way to much time on figuring this out. TIA for any help or suggestions.
P1 13872200 2304791 596.765 Exist Sidewalk
P2 13872201 2304803 596.463 Exist Sidewalk
P3 13872202 2304813 596.237 Exist Sidewalk
P4 13872203 2304826 596.026 Exist Sidewalk
P5 13872204 2304838 595.721 Exist Sidewalk
P6 13872205 2304853 595.652 Exist Sidewalk
P7 13872206 2304865 595.812 Exist Sidewalk
P8 13872195 2304866 595.521 FARM PKG
P9 13872189 2304867 595.554 FARM PKG
P10 13872176 2304867 595.453 FARM PKG
P11 13872160 2304867 595.418 FARM PKG
P12 13872146 2304869 595.116 FARM PKG
P13 13872142 2304869 594.887 FARM PKG
P14 13872132 2304869 594.166 FARM PKG
P15 13872122 2304869 593.624 FARM PKG
P16 13872120 2304866 594.04 FARM PKG
P17 13872118 2304865 595.34 CHIMY PKG
P18 13872118 2304852 595.358 CHIMY PKG
P19 13872117 2304842 595.399 CHIMY PKG
P20 13872116 2304833 595.665 CHIMY PKG
P21 13872115 2304817 596.463 CHIMY PKG
P22 13872114 2304806 597.345 CHIMY PKG
P23 13872114 2304798 597.738 ALLEY
P24 13872124 2304796 597.598 ALLEY
P25 13872135 2304795 597.559 ALLEY
P26 13872147 2304794 597.51 ALLEY
P27 13872160 2304793 597.402 ALLEY
P28 13872172 2304792 597.261 ALLEY
P29 13872172 2304792 597.26 ALLEY
P30 13872183 2304792 597.083 ALLEY
P31 13872192 2304791 596.828 ALLEY
P32 13872200 2304791 596.319 NG
P33 13872201 2304808 595.955 NG
P34 13872202 2304822 595.954 NG
P35 13872204 2304838 595.708 NG
P36 13872205 2304853 595.626 NG
P37 13872205 2304862 595.494 NG
P38 13872180 2304793 596.868 NG
P39 13872181 2304811 595.86 NG
P40 13872184 2304837 595.407 NG
P41 13872187 2304848 594.951 NG
P42 13872186 2304853 595.471 NG
P43 13872170 2304857 595.155 NG
P44 13872170 2304835 595.435 NG
P45 13872167 2304821 595.745 NG
P46 13872166 2304810 596.063 NG
P47 13872165 2304801 596.818 NG
P48 13872164 2304794 597.252 NG
P49 13872147 2304795 597.067 NG
P50 13872148 2304804 596.038 NG
P51 13872148 2304815 595.846 NG
P52 13872149 2304826 595.578 NG
P53 13872149 2304839 595.268 NG
P54 13872149 2304848 595.116 NG
P55 13872130 2304796 597.314 NG
P56 13872130 2304799 597.928 ELEC BOX
P57 13872121 2304800 597.926 ELEC BOX
P58 13872122 2304810 597.933 ELEC BOX
P59 13872131 2304809 597.933 ELEC BOX
P60 13872131 2304809 596.322 NG
P61 13872122 2304810 596.597 NG
P62 13872117 2304812 596.601 NG
P63 13872118 2304822 595.578 NG
P64 13872120 2304841 594.82 NG
P65 13872120 2304852 594.94 NG
P66 13872121 2304862 594.592 NG
P67 13872133 2304867 594.243 NG
P68 13872133 2304862 594.619 NG
P69 13872134 2304850 595.266 NG
P70 13872133 2304840 595.187 NG
P71 13872133 2304830 595.274 NG
P72 13872149 2304855 595.274 NG
Message 7 of 12
Jeff_M
in reply to: IamAwefulatCAD
Which PointFileFormat do you think should match your data, IamAwefulatCAD?
Message 8 of 12
autoMick
You're better off to attach the CSV file rather than paste in to your forum post.
The only issue I could see was that you're point numbers include letters. So I created a point file format that just loaded them as a description field rather than 'point number'. I would rename your points, so that the 'P' is removed. Test your format by loading the file and parsing it using the buttons at the bottom of the format editing dialog box.
I can post some step by step instructions if you need.
Cheers
- Mick
Civil3d user in Australia since 2012.
Message 9 of 12
Jeff_M
in reply to: autoMick
The PFF could also be set to use the PointName instead of Number, this allows the file to be imported as well. That's why I asked them what they expected...
Message 10 of 12
IamAwefulatCAD
Removing the P from point numbers worked. Thanks again!
Message 11 of 12
lekosho2
in reply to: antoniovinci
what was i doing wrong?
Message 12 of 12
Pointdump
in reply to: lekosho2
Olalekan,
Welcome to the Autodesk Forums.
Your GRV PK.csv point file has 6 columns: PNEZDD. If you concatenate the last two columns, then you can use a PNEZD file format. If you want them separate, then you'll need to create a UDP (User Defined Property).
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Rail Community
