326 Kudos
Post 1 of 10
No Plot layer for FL
245 Views, 9 Replies
11-09-2012 09:18 AM
I append the site name to my feature line layers, and in my dwt file I have c-topo-feat set to no plot. Can I get the newly created c-topo-feat-<SiteName> to be no plot? How?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
When the suffix is set in object layers the site name is the default appedage. But never mind it worked when I tested it. I I thought the template was set to no plot but it was not.
263 Kudos
Post 2 of 10
Re: No Plot layer for FL
11-09-2012 10:07 AM in reply to: Joe-Bouza
How are you appending the site name?
I just did a test (2011) and added a suffix manually.  It created a new layer, and it held the no-plot setting from the parent layer.
Credit where credit is due! Give kudos or accept as solution whenever you can.
326 Kudos
Post 3 of 10
11-09-2012 10:13 AM in reply to: troma
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
263 Kudos
Post 4 of 10
11-09-2012 10:21 AM in reply to: Joe-Bouza
Ah... that's where it is!  I was looking for that setting.
Thanks!
263 Kudos
Post 5 of 10
11-12-2012 07:17 AM in reply to: Joe-Bouza
Hey Joe, what happens when you move or copy a feature line to a different site?  Kinda messes with your layer structure?  I guess you just have to remember to change the layer yourself?
245 Kudos
Post 6 of 10
11-12-2012 07:24 AM in reply to: troma
Yeah it would be nice if the layer changed when you change a site...
MatchProperties is how I get the layers and FL styles set.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
326 Kudos
Post 7 of 10
11-12-2012 08:14 AM in reply to: jmayo
That would be nice. As of now I'm happy I can control the no plot setting
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
263 Kudos
Post 8 of 10
11-12-2012 08:44 AM in reply to: Joe-Bouza
I wish there was a way to quickly set all feature lines in a site onto the same style, at least.  You can't even select multiple and put them on a style.  Would be nice if the site had some override settings for display, like a point group.
245 Kudos
Post 9 of 10
11-12-2012 08:50 AM in reply to: troma
In 2012 I can select multiple FL's and assign a stlye to them all en masse by right clicking and selecting "apply Feature Line Style' or by expanding the Site's Feature Line group in prospector, selecting all of the FL's and right clicking over the Style heading to choose Edit. If you don't have the Right click option in 2011 you shold still be able to do this in prospector.
John Mayo, PE
IDSP 2014
245 Kudos
Post 10 of 10
11-12-2012 08:51 AM in reply to: jmayo
John Mayo, PE
IDSP 2014
